We learned here:
...that the fill valve sends water directly into the overflow drain...and that fills the bowl.
However, how does the tank (directly or indirectly) get filled?
Sign up to join this communityWe learned here:
In that particular type of fill valve, the water comes out of the two areas highlighted in yellow in the picture:
By the valve operated by the float.
As the water rises in the tank the float floats and at a certain height that closes the valve which stops filling the tank as it is ready for the next flush.
