AFCI breakers (which NEC now requires on new houses) make a lot of sense. Issues with wires going bad are pretty rare and there's not too many things outside that that can trip one. The likelihood of a nuisance AFCI trip is fairly low.
AFCIs also protect against hidden dangers. Arcing events can happen in hidden locations (like junction boxes) and you might not realize it until the fire department figures out what burned down your house.
GFCIs, however, are much more prone to nuisance trips. Imagine you dropped your hair dryer in a sink. Most GFCIs are next to the point where a grounding event can happen (i.e. inside an outlet). This makes them easy to diagnose and reset. If that GFCI is on the breaker, however, that may not be obvious at all.
GFCI might also be on something you don't want to be subject to nuisance trips. A kitchen refrigerator might get its own circuit, but what about a freezer or mini-fridge?
The final nail in the coffin here is cost. You're going to add a lot of cost to mitigate the small chance that somewhere not already covered by GFCI requirements is going to experience a grounding event.
