EDIT: the outlet is not freely moving behind the cover; I just managed to move it to the side by a fraction of a millimeter and moved it back with some effort. Also, the main question is whether what I did outlined below contributed to any sort of significant damage to the outlet.
I have an urgent question, and would appreciate any sort of help for feedback for my scenario.
I live in the U.S., and my question is about a particular power outlet. This power outlet's receptacle is inserted so that it is behind the cover of the outlet, but it still feels fairly stable.
So yesterday, I was frustrated and yanked out a phone charger from the top socket of said outlet, and realized I had shifted the receptacle/outlets behind the cover to the left by a small amount. Unsure of what to do, I plugged in a plug and used it to shift it back to position, which may or may not have been dumb to do. Now I'm afraid of the integrity of the outlet, whether or not I should use it, or if shifting the receptacle and moving it with a plug was dangerous.
Does anyone know if I should hire an electrician to fix this one outlet, or am I safe? The outlet is on the wall behind my table, which is made out of metal other than the top.
Is it possible for this one outlet to spark or cause a fire due to what I had done before (manually shifting receptacle back to place with a plug in outlet). Also, when I pulled the charger out yesterday, it was not shifted by an extreme margin, but just a little bit.
I'm not sure if it is a hazard or not, since I didn't have any problems prior to doing what I did above, but if anyone can let me know, I would appreciate it. Also, is it dangerous to be in proximity of an outlet, or if it were to spark and electrocute me via the metal table that is next to the outlet?
Main question is: Does moving the receptacle behind the cover damage anything if one were to move it accidentally or purposely with a plug, whether it be yanking it or dragging it?
