One small bathroom in a 1920s house. A cheap remodel was done what looks like about 20 years ago. We moved in recently and noticed water dripping through the ceiling below the bathroom after using the bath/shower. There appears to be a damaged gasket at the bath drain which I will replace. However, it seems that any water getting onto the bathroom floor is finding its way through and into the ceiling below, even small amounts when exiting/entering the shower.
I'm up to my eyeballs in other projects right now, and although I do plan on gutting this bathroom and starting new, that's likely not going to be for 2-3 years. In the meantime, I'm looking for a cheap and easy fix. Is there any kind of transparent sealer I can apply over the top of the existing vinyl to keep it watertight for the next few years?
Unless there are holes in the vinyl flooring it is probably getting through where the vinyl meets the tub or the wall. Just use a clear or white 100% silicone bath caulk to seal those junctions.
Make sure it is rated for resistance to mold/mildew.
  • Thanks. I plan on sealing up the seam around the tub, but I think most of the leaks are coming through the joints in the vinyl tile. Perhaps I'll just try to smooth a thin layer of silicone over the worst offenders. Dec 5, 2018 at 18:59
Along with Alaska's suggestion, a bath mat should solve your woes, and a little more splash discipline from shower users. Trying to make a bathtub out of one's bathroom floor always seemed a little silly to me.
  • I agree that a bathroom floor shouldn't need to be made into a bathtub, but bathroom floors should be able to sustain some occasional splashes or moisture without damaging the ceiling below. A few small but well placed splashes were all it took to get dripping into our dining room. Dec 5, 2018 at 19:00
