Thank you beforehand for the help.
Issue we are experiencing is that we have a bathtub hot water valve that has started to leak again after replacing the washers about a month ago. Mind you this could be because of the weather being more cold but not sure.
What could be the actual issue and would it possibly need professional assistance with replacing the main part of the valve in the wall?
We have separate hot and cold valves and the cold side is working/sealing fine -- we haven't had to replace that as of yet, however, the hot water side is a bugger. This is the second time we've had to replace the washers.
Again, any help would be appreciated.
