I would like to tile around the inside of my fireplace but I am unsure what type of grout I should use. My only problem is the stove can produce an extreme amount of heat, therefore, causing the tiles to fall off if I use the wrong type of grout.
Is there a type of grout, cement or adhesive that is resistant to extreme heat?
Note: the tiles of which I will be using are fire and heat resistant.
Below is an image of the area within my fireplace of which I am tiling: (note: at the time of tiling the wallpaper will be removed)
Thanks.
