TL;DR - Furnace/AC generates a lot of rust flakes and ash, not sure what this means.
UPDATE - An inspector came by to look at the furnace. While the inspector didn't find anything broken, he said it was nearing its end of days, and that it was only a matter of time until something broke. As per his recommendation, my apartment complex replaced the unit.
I live in an apartment unit that's 34 years old, and I'm a little concerned about the state of my furnace and AC unit. I don't know exactly when it unit was installed, but it seems to be showing its age. I noticed an excessive amount of rust flakes and, now that the gas heater is flexing its muscles for the cold this season, some ash. I honestly don't know much about HVAC systems in general, so I took some pictures. Is the condition of my system any cause for concern?
This is where most of the rust would pile up. I have cleaned most of it off. Before I did, it would simply drop to the ledge and floor below.
This is underneath the rusty ledge, looking at the burners. You can see some of the rust that fell from above, as well as some ash from near the pilot light.
A closer view of the pilot light, showing the rust flakes and ash piling up below. The ash was not present before this season when the heat kicked in.
Underneath the rusty "hood" in the first image, there are two holes where it seemed most of the rust would fall from. It was a little difficult to get a good picture of these holes, so please excuse the poor camera work on my part. This is the left one. I'm not sure what the larger bits once were, but they don't look or feel like metal or rust. My guess is that at some point this hole was partially covered by some material that fell apart through the years.
The right hole didn't have the same non-metallic flaky bits, but did show a good amount of rust flakes sitting inside. I'm not entirely sure what these holes are for, but again, I'm not very familiar with these systems. It seems like a majority of the rust comes from these holes and drops onto the rusty "hood" (first picture). I lightly brushed my finger along the outer rim of the hole and rust eagerly fell out.
This last picture is of the floor below the unit. You can see a small section where I dragged my finger through the rust that had piled up. I doubt this picture is very relevant, but I included it to give a scope of how messy this system is.
I know this is a long post, so thank you for reading it through. My question is, should I be concerned about the excessive amount of rust accumulating through this system? As far as I'm aware, the furnace and AC work alright apart from being noisy and inefficient.
