My question is how much load can my 2 each 6 x 6 pre-treated post handle. I have approximately 1,466 lbs of treated wood as my roof of the pergola and it will be attached to the house the other will be 2 each 6 x 6 post in concrete in the ground. I wanted to hang a swing between the 6 x 6 post (350 lbs max weight). My span between 6 x 6 post is 12 ft center to center. I have 2 x 12 x 20 bolted on each side of the 6 x 6 post. I wanted to hang my swing from that.
Will my structure work? Will 6 X 6 post handle 1,466 lbs plus swing 350 lbs? Is this structure design sound for this application?
