I just had a perimeter drain and sump pump installed in our crawlspace because it flooded frequently and severely during the rainy seasons. Before, I was under the impression that leaving the crawlspace vents open was the way to go in this climate (very wet winter/spring, very dry summers). Now, with the drainage system in place, I'm leaning toward closing off the vents, since (if the drain/pump system works) there will be no more standing water, and thus much lower humidity levels, and it would slow down the inevitable fouling of the new plastic sheeting from dust and such.
So, to seal or not to seal?
Thank you
Steve
