my kitchen has 3 lights that are not working. One dining table light a over the sink light and the main kitchen light which were 6 T12 lights replaced with 6 LEDs (t8's)that required no rewiring. all the wall receptacles have power and are working. Here is what I did so far:
-checked the gfci outlets and none of them were tripped but I pushed reset anyways.
-went outside to my breaker box and none of those were tripped but I also reset them all anyways.
-took all the switch covers off the light switches and tested that they all have no power.
-checked the wire nuts behind the light switch and they're all very secure.
-took the breaker panel off and tested each breaker. all had 123V.
What should I do next? Im thinking replace all the light switches?
or check all the wall receptacles... I assume all kitchen lights and wall outlets are separate.
any other options out there, please help. i havnt checked the light bulbs themselves because like all the lights are LED...I slowly upgraded them over a period of like a year. with the last ones being about 4 months ago.
