I hung drywall ceiling in my basement. I got impatient/lazy and decided to "finish" the project already by painting it with Kilz PVA Drywall Primer, even if the mudding & taping is not perfect yet.
I would say some taped joints need one more layer of mud & light sanding to be completely hidden (especially the outside corners with the CGC Perfect 90 tape (If I used normal folded paper tape, It would've shown less).
I haven't painted it with Latex. The primer is white and flat, which I think looks OK for now.
Should I decide to "fix" it, can I mud over the PVA primer?
    Being a hack taper myself I've fixed my work after priming many times. It's never been a problem.
    Commented Jan 27, 2017 at 20:52
You can absolutely mud over cured primer. (Or cured finish paint, for that matter.)
Use all purpose mud (not a setting compound) and scuff the primer gently with 120 grit.
  • Why do you say to not use a setting compound? I'd expect it to work as well there as in other situations.
    Commented Jun 23, 2020 at 18:30
  • Suggested AP because this is supposed to be the last skim, and hot mud is harder to sand (and get that perfect feathered edge). Commented Jun 24, 2020 at 11:33
-2
Polyvinyl acetate dissolves in water and the mud is water based too. There is a possibility of the mud detaching and falling off. (Happens all the time) I would recommend sealing in the primer with a waterproof latex with texture. The texture will help the mud adhere better.
  • If that was the case, wouldn't the primer dissolve with the application latex paint and discolor it?
    Commented Jan 27, 2017 at 22:16
    Cured primer does not dissolve in water. Period. Commented Jan 27, 2017 at 22:26
-2
Kilz PVA Drywall Primer is a product to be sold to amateurs that have no clue how drywall should be finished. It is not a cure all. The product can be utilized by spraying it on preexisting drywall to ensure the compound adheres the wallboard. Exp. if one wants to remove a textured ceiling and wants to apply joint compound afterward I would suggest using it to insure the compound adheres to the wallboard instead of "flaking" after the paint prime coat has been applied.
    Reading around the "rant", is seems like your answer is "yes, you can mud directly over the Kilz". Am I reading this correctly? If so, it would be good if you edited your answer to state that clearly and remove the opinion parts. If you'll take the tour and read through the help center you'll find that this site is different from most in that we're looking for authoritative answers, and "rants" are explicitly off-topic.
    Commented Jun 23, 2020 at 17:24
  • Also, this is a 3 year old question, and your answer doesn't really add any additional info to the upvoted answer which says the same thing - "Yes" you can mud over it.
    Commented Jun 23, 2020 at 17:35
