I have a ceiling (house from 1956) that was mudded and primed 2 years ago. This was done on top of a new paint job.
The ceiling had originally "popcorn" structure and was mudded flat. However, the mudding job was pretty bad and so I decided to add a layer of topping mud to get it more smooth. On my final lightly sanding phase, I noticed small cracks and stuck a taping knife into it, and found that the initial mud job (or paint?) was not sticking to the old surface. Didn't take me long until I had removed most of the ceiling mud, see picture below. It would come off in large sheets, and was sticking solid only at a few places.
What is the best way forward here?
Tips on what todo with the "islands" that are real hard to scrape off?
I figure
- I scrape off all that I can scrape off
- clean the surface (tsp?)
- prime (not the islands),
- Re-mud the whole ceiling with heavy all purpose mud?
Or, is there another way? Missing anything?
Regarding primer, can I use Kilz water based or should I use something "better", like a shellac based one, in order to avoid the mud to come off later on, again!
I figure the initial surface was not properly primed (on top of the paint)? Thanks!
