I recently moved to an apartment with no ceiling lights. All wall switches are wired to a specific outlet in each room. Unfortunately, the switch each one controls is in the worst possible location and I can't do any re-wiring.
Is there ANYTHING like what I'm about to describe?
I would like to plug a device to the outlet controlled by the switch and plug a second device to a better located outlet of my choosing. A lamp will be connected to the second device. When I turn the switch on, the first device will send an "ON" signal to the second device which will in turn power up the lamp hooked to it.
