I keep looking for a situation like mine on this website and other websites, but I was unable to find one.
A 3 wire oven (two insulated hots and 1 bare twisted wire) is connected in an old main panel where the neutral and ground bus bars were bonded. A new main panel was setup elsewhere, thus, the old main panel with the oven was converted to a subpanel and the neutral and ground bus bars were separated.
FOR NOW, should the bare twisted wire be on the isolated neutral bus bar or on the grounded bus bar? The oven is plugged into a 3 prong outlet.
I understand that an updated oven now has 4 wires: 2 hot, 1 neutral, 1 ground. I can add in an insulated neutral wire and change the outlet at a later date when the oven is updated.
