My front door does not close squarely. The hinge side closes flush. The lower corner opening side touches the weatherstripping fully. But the top of the door does not. The door has about 1/2 inch difference on the top edge, where it does not completely engage the weatherstrip. Obviously the door or frame is somehow not square. Let's assume removing the door and replacing it (or the frame) isn't an option at this time.
Is there any kind of "tapered" gasket or trim material I could purchase in order to then take off the weather stripping and replace with a "fatter" strip that will seal, or take off the weather stripping and put in a long tapered (3 foot and 7 foot) edge material (wood, plastic) to match the door, and then put new weatherstrip on that will close fully.
My other idea was to put a deadbolt on the upper corner of the door and when I push it closed, engage the lock and it will keep the door closed and sealed. But I don't like that idea much.
Any other suggestions appreciated.
