I received a Kenmore upright freezer from a family member. As far as I know, it was working fine for several years. That family member moved and no longer has the space for it, so now we have it!
It has been plugged in for a month. The first three weeks seemed fine, but about a day ago, I opened it up to find quite a bit of frost: Imgur Album of Frost in Freezer
It is one of those freezers that vacuum seals itself when you close it. Yesterday I noticed ice build up around the latch that you engage when you want to lock it. This to me was interrupting the seal so I cleaned that out. I checked it this morning and it seemed to be the same amount of frost...if not more! Do I need to clean the frost out and see if it re-appears? Might there be other problems? I haven't done the dollar bill test yet.
