Last night I turned my AC down a couple degrees before going to bed. The AC was running at the time, so when I set the temp below the current temp, the blower turned off. After getting in bed, however, I could still hear the hum of the AC unit outside. I went outside to be sure. From the thermostat I turned the blower to manual, and sure enough, cold air came from the vent. I turned the blower off, the AC continued to run...
I then turned the thermostat from 'cool' to off. Still, the AC kept running. I wan't really sure what to do because it was 11pm. I unplugged and plugged back in the thermostat. Still it continued running...
Eventually, maybe 20-30 minutes after initially adjusting the temp, the unit finally shut down. I turned the thermostat back to cool, now set to 78 degrees, well above the current temp. The next morning I turned the temp down, the systems came on as usual, and after a few minutes, shut down as usual -- twice before I left for work.
Is this a one-off thing? Should I have the system serviced?
Also, the AC is on the interruptable circuit, but the light was green (circuit open) when this was all happening.
Any ideas? Thanks.
    When you say you "turned down the AC", do you mean you set the temperature to a colder or warmer temperature? – wallyk Jul 25 '16 at 16:52
    Is it a cooling-only unit, or is it a heat pump? Has the system worked okay before? Is it recently installed/upgraded? – wallyk Jul 25 '16 at 16:53
  • Usually AC units cannot be cycled on and off quickly. They take time to reset once they are off until you can turn them back on again. – ArchonOSX Jul 25 '16 at 17:54
  • The system is around 14-years-old, and is a cooling-only system. I also have a gas furnace -- necessary here in MI. By, "Turned the AC down," I mean increase the target temperature on the thermostat. – BenW Jul 25 '16 at 19:59
It was a sticky relay. I should have just hit the AC unit and the relay probably would have un-stuck, but only to have gotten stuck again later. I could have just cleaned the relay too, but I had the HVAC guy replace it with a new one he had on the truck.
