Why is the sump pump inlet draining directly onto the float? Won't this prevent it from rising most of the time?
    Perhaps a picture would help. I have no idea what you're describing. Since you have a low rep, just upload it to imgur.com and put the link in a comment and someone will edit it into your question.
    – Tyson
    Commented Jul 17, 2016 at 0:41
    Photo, please? The sump pump's inlet should be at the bottom of the pump, well below the float, and it's output should be through a check valve to a pipe or hose that sends the water somewhere else. There shouldn't be any mechanical interference with the float, and it shouldn't be "draining onto" anything.
    – keshlam
    ... or do you mean that the sump inlet is aligned with the pump's float? If so, there usually won't be a strong enough stream of water coming in for this to be a problem.
    – keshlam
    Commented Jul 17, 2016 at 4:16
Totally not a problem - if it was a problem, the sump would be overflowing and you'd be asking about the flood.
The force of a stream of water coming in from a side pipe to a sump is quite minor compared with the force of the collected water pushing up on the float.
Assume that it DID affect operation - once the water had risen to the level of the pipe, the incoming water would be flowing straight in OVER the float, and the float would not be affected. But I bet it never even gets close to that point, in reality.
If you like, take a 5 gallon bucket or a hose and dump/run water directly onto the float and watch what actually happens.
