I just drained the hot water heater, as I do every year (using the following video for instructions: https://youtu.be/qqaehhGYV_I). This time, the pressure relief valve had a slight hiss after I refilled the tank and closed the valve.
I noticed today the discharge valve on the side of the house is spewing hot water continously from the hot water heater.
Do I need to replace the pressure relief valve, or what is the issue?
