Cack handed DIY amateur here.. I need to cut engineered wood planks lengthwise - they're 4mm oak on a 10mm MDF base. I'm having trouble getting a jigsaw to cut straight. With a "clean wood" blade the jigsaw almost immediately starts bouncing up and down vertically, even with a tight hold on the saw it feels like it's about to fly off. With a standard wood blade the saw stays down, but the cut veers off to the right in a banana shape. I've tried clamping another piece of wood to the top to steer the runner against and clamping the whole thing to a table, but it doesn't seem to help. I'd be grateful for any advice. Am I using the wrong tool maybe?
Wider jigsaw blades are less prone to bending.– Wayfaring StrangerSep 3, 2015 at 22:28
Also see: diy.stackexchange.com/questions/51300/…– EcnerwalSep 4, 2015 at 2:30
If this is flooring, the core is probably Hdf (high density fiberboard), which is rough on all saw blades. If you're stuck with a jigsaw, you might try a blade specially designed for flooring. (Just an example -- not one I've used -- Bosch T101BIF.)– Aloysius DefenestrateSep 4, 2015 at 4:26
1 Answer
You are, IME, IMHO, using the wrong tool, definitely.
- A (sharp) hand ripsaw would be preferable.
- A circular saw would be preferable.
- A bandsaw would be preferable.
- A tablesaw would be ideal
...but a circular saw is far less expensive than a tablesaw and still pretty capable with a rip guide.
Hire a table saw from a local tool hire firm. You will not regret the quality of finish it gives on the flooring panels. Sep 5, 2015 at 9:19
