I recently purchased a new refrigerator and in doing so want to swap out the copper ice maker line for a stainless steel flex line. In order to do so I need to make the water line access hole to the basement bigger from about 1/2 inch to 3/4 inch. Do I need a carbide or diamond tip drill bit to do this? I don't think the tiles are glazed.
1Diamond is maybe better but I really think that any would be good.– python starterApr 20, 2015 at 18:55
Your fridge is sitting on the hole or covering it right?– DMooreApr 20, 2015 at 20:20
Yes, its directly behind the fridge– Steve SalowitzApr 20, 2015 at 20:58
1 Answer
A few possibilities...
Probably the cheapest (though not necessarily going to work in your setting) is a 3/4" ship auger drill bit through the plate of the wall behind. A slack jawed yokel would just set the bit at an angle through the drywall and go for it, but a sensible individual would open up a small hole in the drywall beforehand to see what they're drilling through. Hitting plumbing/electrical/etc is not in anyone's best interest.
Next would be a diamond grit hole saw. The only bothersome part of this approach is that you'd have to make a 3/4" hole in a scrap of plywood big enough to stand on. That would guide the hole saw and keep it from walking. If you do this, don't center the 3/4" hole saw exactly on your 1/2" hole. Have the rim of the hole saw go through a little bit of empty space in the 1/2" hole, so that it can drain dust and minimize clogging.
Least appealing would be to use a 3/4" hammer drill bit, but if you have other uses for such a thing (and a hammer drill that can actually drive something that big), it might be an option. On low speed and and not on the hammer setting, make the hole bigger. Too much pressure, and you run the risk of cracking the tile. (Not enough pressure and you'll be there for days.) Once you've opened up the tile, the drill bit won't go through the floor very well, but you can probably push your way through with a little more drill speed. From your description, it doesn't sound like you have porcelain tiles, but if you do, avoid the hammer drill bit like the plague -- I assure you that it won't end well.
