I'm trying to replace my living room ceiling light fixture. The new fixture only has black and white wires (no ground). The ceiling has red, black, white, and ground wires. When I took the old fixture down I noticed that the black wire was connected to the red wire from the ceiling and the black ceiling wire was capped off so I did the same to the new fixture but the light will not turn on. Help!!
PS. I've also tried connecting black to black and no luck either. I connected white to white and left the ground wire alone since my new light does not have a ground wire.
ON
position? Are there bulbs in the new fixture? Are the bulbs good? – Tester101 Mar 5 '15 at 18:40
