Recently we had an overflow from our washing machine, because we washed pillows on the high speed setting. The powder room where the washing machine is located had water on the floor underneath, but thankfully it was limited to one corner. We attempted to dry the area with fans, and now have a pan in place to catch some spills.
We checked out the area a month later, and noticed that the top of a few boards are lifting in an area and there are some black bits. I uploaded a YouTube video of the damage
I suspect it'd be best to replace the damaged floorboards, but that's beyond what I can do in the very short term. My preferred flooring guy is booked steady for a while, and it's a decent round trip for him. I was going to start with the approach for removing stains, but should I remove that board to investigate further?
I'm assuming this is tongue and groove board so it'll be trickier to remove. Is it safe to just remove the surface area that is lifting, dry that further, prep it and apply polyurethane as an interim solution. If there is an easy way to remove the board and avoid collateral damage I'd be interested in knowing that.
