My 3 year old put some of his toys down the furnace duct (as one does) and I can't reach them. They are in the elbow pictured here:
I've never encountered this type of joinery before on duct work and I don't want to accidentally break something and not be able to get it back together.
The vent/outlet/register is embedded in spray foam (some of which you can see on the left of the duct pictured) so it's not feasible to remove the pieces from the floor.
Should I just cut a hole and seal it back up with aluminum tape?
