I have a couple “order of operations” questions regarding our kitchen we are upgrading.
We will be installing glue-on tin backsplash from American Tin Ceilings above 4in quartz backsplash up to the ceiling , the wall behind the stove, and under the upper cabinets. Do I caulk the gap between quartz backsplash & wall and other similar gaps before or after the tin installation? (It’s similar to wallpaper but thicker)
We will be installing decorative wood trim around the cabinet edges —do I install the cabinet trim before the glue-on tin backsplash or after?
