I'm adding insulation into a room I'm building here in the PNW. The insulation is unfaced R-30 fiberglass roll. The room is in an unfinished attic space with the ceiling, and two of the walls are external while two are internal.
What kind of material can I use as a vapor barrier for the insulation? Can it just be thin clear plastic painter's tarp? Can it be any kind of 6 mil plastic sheeting? Does it have to be specifically for "vapor barrier" purposes?
I've already gone through and purchased (and applied) some vapor barrier already. However, I've realized that the amount I would need to complete the remaining space would be cost prohibitive if other cheaper options exist.
Thank you in advance!
