I'd opened up the subfloor in my second-floor bathroom to relocate the plumbing from the floor to the wall. Before I patched the plywood subfloor, I found out that these flat 2x4 joists are engineered floor trusses. The thing is, I want to ensure that the plywood has enough support on the right end, next to the wall, as there is no joist support underneath. I am considering using a :
- square brace: flat 2x4s arranged in a square shape, nailed to the joists on both ends, or
- Adding a 2x4 flat as blocking between the joists.
Would this be an issue with trusses, and if there is a better way to do this?
