Edit: Never mind. I found a 24 amp charger with a 10-30 plug for only slightly more $ than the 14-40 charger I was planning on getting, so I'm going to leave the outlet as-is.
I turned of the 30A breaker and used my non-contact voltage tester to make sure these wasn't any voltage at the outlet. When I pulled the cover plate off the NEMA 10-30 dryer outlet in my garage (built in 1994) in preparation for replacing it with a NEMA 14-50 outlet so I can plug in a EV charger (drawing 24 Amps), I was happy to see that there were 4 wires coming into the box. I was surprised, however, to see that the bare copper (ground) wire was connected to the neutral terminal of the outlet, while the white (neutral?) wire was not connected to anything. While the dryer has been working fine for 30 years, from what I've read, that is not up to code, even prior to 1996. Since that seems wrong, I'm concerned what else could be screwed up (specifically is the white wire really the neutral), and want to test things before I install the NEMA 1450 outlet.
With the breaker still off, I verified that there is continuity between the bare copper wire and a nearby water pipe (for the washing machine), so I think that means it is a good ground wire, but I don't know how to test that the white wire is a good neutral.
My question are:
- Am I correct that the existing wiring connection the ground wire to the outlets neutral connection is not up to code?
- Is testing continuity between the bare copper wire and a nearby water pipe a correct way to test that it is a good ground wire?
- How can I test that the white wire is a good neutral?
