This is in NW Washington, climate zone 4-C. R-49 required for roof insulation.
I have a 100-year-old, partially-finished attic that I plan to gut and re-finish in the coming years into proper living space. I've gone back and forth on strategies to insulate this space both to code and for longevity.
My current plan is as follows.
1” foam board for ventilation chute (R-5)
- Minimum 1” air gap under roof sheathing
- https://www.finehomebuilding.com/project-guides/insulation/rigid-foam-vent-baffles
½” drywall (R-0.5)
6¼” closed-cell spray foam (R-7/in)
This gives me 1” x 5 + ½” x 0.5 + 6¼” x 7 = R-49.25
The current roof system is standard 2x6 on a 12/12 pitch. To achieve this insulation level, I'd need: 1” air gap + 1” foam board + 6¼” closed-cell foam = 8¼” rafter depth. Meaning I need to add 2¾ to the rafter depth.
An alternative thought I had was to slightly reduce the spray foam depth and add an additional 1" of foam board on top of the rafters before hanging drywall, which would reduce thermal bridging from the lumber.
Am I on the right track? Are there better/alternative solutions I could be considering? My main concern is maintaining as much interior space as possible.
