While I was gone for a couple of days my water meter reading changed by about 60 gallons, or ~30 gallons per day. With traditonal style water meters it was obvious if water was moving through the main valve, but new-fangled electronic water meters were put in over the last year...sigh. So question 1 is does anyone know if the icon circled if the attached image indicates anything? I am a pretty good guesser so I don't need any of those, just would like someone who is sure/has direct knowledge knows if it means anything or not.
2nd questions is, if I do have a leak (still an assumption), I can say it's not any of my faucets or water valves (e.g. washing machines, toilets) inside the house...I think I'd notice 30 gals per day leaking into the home. So where would it be leaking from? How would I go about locating with certainty? I walk around my small home perimeter on a near daily basis and have not seen any indication outside, either.
