We just moved into our new construction home 3 months ago. Very fine hairline cracks have started to develop in the top corners of the bathtub ledge (they are very hard to see in person without a flashlight, so not anything extreme). We also just noticed inside the bath, what we thought was them just spilling some grout, is also tiny little holes/defects in the finish.
How rapidly do things like this get worse? Also, is it still safe for our child to take baths? Is this an easy fix or should we be contacting the builder? I’m really worried maybe the tub was installed improperly. We previously had an issue right before move in with the hot water pressure in the tub, which they fixed, but then resulted in a leak, which they also fixed. Thank you for any insight!!
