Installing a new tub and needed to move the ptrap. Please let me know if the proposed angle poses any problems.
Why does the joist with the hole look skinnier than the other joist? Am I hallucinating that? It looks substantially skinnier.– pophamCommented Dec 9, 2023 at 20:45
Off hand, it looks to be a 1" board put in as a patch after cutting out the joist there. On the other hand, there appears to be vinyl tile floor directly below the lumber, like this is a raised section over an old floor, so it may not really be a joist as such.– EcnerwalCommented Dec 9, 2023 at 22:36
1 Answer
If the large vertical offset to the drain is only for the picture, (because you have't cut that pipe to connect to, yet) this is fine - the P trap can be contorted in any way horizontally without changing its function.
But if there's a vertical drop of one pipe diameter (or somewhat less, depending on the applicable code) into the drain, that makes it an S trap, and those tend to siphon dry and give your tub sewer gas problems.
Using a sanitary Tee laid on its side rather than a Wye to enter the larger pipe is a pre-existing code violation.
