Water and wind blow through this exterior door. Its freezing and I can see light through. Unfortunately the landlord is no help.
The frame is very crooked. On the knob-side of the door there is about 1.5cm gap between the door and frame near the bottom, vs few mm gap near the top.
already filled the gap in the side with expanding foam stripping. But still need to fix:
- doorknob keeps coming loose
- drafty spot at bottom corner of door even after applying weather stripping pic
- the seal at the bottom edge needs replacement but not sure what kind given that the frame is uneven
This is an exit door so I can't cause permanent damage/obstruction.
I have basic tools and access to the the hardware store. Hopefully there is a simple fix.
