Currently Grinding a concrete floor flat for hard flooring and using an angle grinder with a diamond cup bit and a dust cover.
I have the vacuum like attached to a dust rite separator and then to an old 10 gal rigid shop vac with a regular cartridge filter and the filter clogs fairly quickly. I have taken it off and tapped it.
Can I run the vacuum line outside of the house and just run the shop vac without the filter or will it destroy the vac? Is there a better solution as well?
The shop vac is old and beat up so if its unusable for inside use after, its not a loss, but I would like to finish the work.
