North Florida usually stays above 45 Farenheit: the heat pump defrost mode is rarely needed. My neighbor's controller board has been replaced two times and we would like drill down to root cause.
- How does one determine if the system is of the "Time-Temperature" type or "Demand defrost" control?
- What can be done to protect the board from over / under voltage?
