I bought a house a month ago and I'm having issues with a crawl space door located right next to the upstairs air return. The door is not insulated on the other side and smells/heat from the attic seep in all day and night causing a musty smell being circulated upstairs. The thermostat is also just off camera so unless I turn it up to 80, it will run all day because that corner STAYS hot.
I'm handy but not in any way shape or form educated in the ways of proper construction so don't flame me here. I considered hanging some sort of insulation blanket or roll out insulation just inside of the door. I could just roll it up or treat it like a curtain when I need to access the attic from here. Perhaps even seal the door with silicone and peel it off whenever I need to access it.
Any advice?
