I got 4” Led lights outside my home. I have 6 lights out and I am having a hard time find the right connectors for jbox. I need 3 male connectors for jbox but can’t seem to find. Is this possible or do the joboxes need to be replaced?
3Why do you need male connectors? If the light is bad and you get a replacement it will already have a connector. What are you doing? Also ... why do you have six lights out? That's unusual. Before you replace them you should figure that out.– jay613Commented Jun 25, 2023 at 19:20
Add a comment
1 Answer
Each Ultra thin LED should have an accompanying driver/ j/box.
If you are trying to connect new light to older driver boxes, they may not match.
It is highly unlikely that 6 lights would go out at the same time. You would be better off checking the wiring in the boxes. A bad connection in one box can cause all the lights downstream to be out.
