I'm building a retaining wall from concrete blocks. The foundation will be 8 inches of 3/4 inch gravel compacted with a plate compactor. The trench is dug, but it has rained a good bit the last two weeks, and while not soggy things are wet. (There are no puddles in the trench, all the rain has been absorbed into the ground. I can walk in the trench and hardly leave footprints.) How much should I allow the ground to dry out before adding my gravel and compacting? Is it bad to compact onto ground that is wet but not soggy?
1 Answer
The rain helped compact the soil for you. In the current state your ground is good to go for gravel and compaction.
And if it wasn't then you should go get a hose and wet it. Ideally as you're back filling. With a tamper you probably don't want any puddles splashing you, but with a compactor? Go nuts.– MazuraJan 15 at 5:17
