What is the best and easiest way to fix these issues? I assume I need to scrape away the bad grout with a grout saw, and then re-grout. Is there an easy to use product I can use instead of actual grout? Do I need to go ahead and re-grout the entire shower? The third picture shows the state of most of the tile grout.
I have already tried cleaning the grout with vinegar, and then with bleach.
Worst Grout
Second worst corner
Other Tiles
  • Why do you think you need to replace the grout? Try some type of grout cleaner first, starting with something benign (like baking soda & vinegar), then move up to a stronger commercial product. If all that fails, a strong bleach solution will work. At least it did in my shower.
    – SteveSh
    Commented Jan 4, 2023 at 0:10
  • @SteveSh I have already tried cleaning the grout with vinegar and bleach. I edited the post to clarify.
    – SCC
    Commented Jan 4, 2023 at 0:22
It looks like most of the mold is growing, not on the solid grout between tiles, but on the flexible sealant (presumably silicone) joining the tub to the tile walls and joining perpendicular walls to each other. (If the edge between the tub and the tile is actually grout rather than silicone, that's a whole different problem.)
I suspect that this happened because the sealant was tooled into an incorrect shape that allowed water to pool against it rather than flowing down into the tub. The silicone appears to be peeling or broken in places, which could also be letting water in. Either way, removing the mold won't solve the problem, since it will keep coming back until you fix the silicone.
So your main task will be to remove the existing sealant and replace it with new silicone.
Note: you should never grout vertical corners between tile walls. Since grout is brittle, it tends to slowly crack as the walls settle over time; you should always use something flexible to join perpendicular surfaces. Those joints should always be silicone. A lot of people get this wrong, to be fair.
  • Not entirely true. That's a good recommendation in cases where there's danger of movement of the perpendicular surfaces at the corners, but if the substrate behind the tile was installed with potential movement in mind, there's no problem with grout in the corners. 100% the seam between the tub and the tile should be caulked. That will move with the added weight of water (and people) in the tub. I've seen more showers grouted at the corner than not in my life and the vast majority are as they should be.
    – gnicko
    Commented Jan 4, 2023 at 1:18
  • @gnicko: See this earlier question: diy.stackexchange.com/questions/175505/… -- It is true that many showers are incorrectly grouted at the corners, but caulking is correct whenever tiles are connected to different walls. (Unless you use fancy epoxy grout, which is less common.)
    – alphabet
    Commented Jan 4, 2023 at 1:19
  • Fair enough since we don't know what's going on behind the scenes in the OP question. But there's no problem with using grout in the corners if the wall and the substrate behind the tile is done correctly. If the corners are going to move enough to crack the grout, chances are you've got bigger problems. Besides, caulk tends to grow mold and needs to be replaced every few years. Grout, even if it cracks, requires less maintenance.
    – gnicko
    Commented Jan 4, 2023 at 1:36
  • It depends on the silicone you buy! Good silicone, applied well, will last a decade. If you get GE Supreme silicone (the really fancy kind), it is extremely mold-resistant (unless you let water pool against it, which I suspect happened to OP).
    – alphabet
    Commented Jan 4, 2023 at 1:47
I soak bleach into a shop towel and let it sit against the surface for 8 hours. This typically kills any mold. Generally I use this at the caulking seams. The grout lines that you show is likely easiest to give them a quick sand with a grout saw and then use a grout sealer to prevent it happening again.
  • I concur that this works amazingly at removing mold from silicone/grout although it isn't a permanent solution.
    – AWGIS
    Commented Jan 4, 2023 at 13:33
It looks like someone already tried easiest where they replaced the grout in the corners with caulk. To one degree or another, that's contributing to the problem you're having now.
I'd dig out the caulk in the vertical corner and replace it with actual grout. The rest of the grout can be scrubbed up with some grout cleaner and look good as new. It's the caulk that seems to be growing mold, etc. and it should be replaced. Grout cleaner and bleach, etc. don't work on caulk as well as it does on actual grout.
While you're at it, and working on the tub, you might as well re-caulk the seam between the tub and tile as that seems to need some attention in places too.
