About 3 weeks ago, we had a problem with our toilet. The toilet is on the first floor. It was leaking. We called in a plumber who said that the wax seal was bad and he fixed it. After doing this, we had an insulation person come in and remove our old insulation in the ceiling of our basement. For the most part, he did not put any insulation back. However, in certain places he put foam insulation in including around the waste pipe of the toilet.
Yesterday, I discovered that the toilet was moving when I was sitting on it. I called the plumber and he came out today to fix the problem. He believes the problem with the toilet was caused when the foam insulation was put in. He explained that when the foam insulation is sprayed on, it expands. This expansion caused the problem. They also put up a generous amount of foam insulation around the waste pipe of the toilet. He fixed the toilet without charge.
Do you think the problem was caused by putting up the foam insulation?
