That's not a typo in the subject line.
I am finishing part of my basement to put in a new master bedroom, bathroom, and closet. I was planning on putting the panel in the walk-in closet but enclosing it in a full enclosure of the appropriate size (floor to ceiling, 30" wide, 36" deep), but the inspector said that is not allowable because the panel would be in a closet in a closet and since the outer closet is a clothes closet, the panel is still in the "vicinity" of ignitable materials. I don't quite understand this since there will be a solid layer of finished wall between the panel and any ignitable materials. Thoughts?
I then came up with a second idea to still create a "subcloset"; however, this time, it would have a small door leading directly to the bedroom. The panel would still have the appropriate clearance, but to get to that clearance, the "hallway" (about 3' long) would only be about 18" wide. Without me providing exact dimensions of the door, the inspector approved this idea via email but said the door to the panel must be at least 24" wide. Is this correct? Would this separate closet need a door of at least 24"?
Thanks!
