Summer is coming and I live in an apartment where the window can slide up to insert an AC.
Unfortunately, after some time I get bugs and mosquitos coming through the gaps around the AC and at the top of the sliding window (since it is only sealed when it's completely closed).
I tried to use caulk tape, but it wasn't very effective. There'd still be tiny gaps here and there that things found a way through.
I'm now thinking that there must be some kind of foam spray that can do a better job of sealing off gaps. Is there anything like this that is non-toxic and easily removable? TIA
