I recently bought and assembled a MALM desk. The assembly went smoothly with no issue until the last step where I need to attach the door.
The hinges and the brackets are screwed in in their right spot. I managed to fit the hinges in the bracket and slided them right but then it's impossible to tighten the screw on the bracket in order to firmly attach the door. The screw can only be loosened and tightening to the maximum leaves a wide space between the hinge and the bracket so the door is left hanging and unattached.
I've been struggling with the problem all night so any help will be greatly appreciated. Thanks.
