I am using Rainbird brand irrigation kit to water my garden and am trying to find the optimal layout for the sprayers. The kit i bought connects from a standard garden hose to the 1/4" hose that can be configured with about 12 sprayer/bubblers attached. Problem is i'm losing pressure about halfway though the setup.
Here is the current setup. I begin to lose pressure around the third set of sprayers. the last four have little to no water coming out:
I'm thinking of actually forking at the water source before the sprayers, then having 6 on each branch instead of one line trying to power all 12. So something like this:
Which one would be a more efficient use of water? Or is there another setup i should try? Maybe every sprayer has it's own line off the main line?
