I have a wiring problem after replacing an outside outlet. I checked my wires with a multimeter, Hot is 121v, the common shows good and ground is good.
When I place a plug in 3 light tester it indicates wiring is correct. I show 121v with meter on hot and common. Also on hot and ground. But, nothing works. Not even a 5w night light.this line goes through a GFI outlet. Which tests good, and when tripped also shuts off new outlet.
What am I missing?
