I am a DIYer and would like some advice (even if the advice is "call an electrician").
I have a house built in the 1950s. I have 2 independent electrical panels from the meter-1 inside, the other outside. B & W wires initially run through conduit. While running a new circuit from the inside panel, I needed to get easier access, so I pulled out a breaker and disconnected the white wire from the bar. This circuit ran to my pantry.
Now, with the inside panel turned off and the outside panel turned on, both the disconnected B & W wires that ran the pantry are hot (per voltage detector).
When the B & W wires are connected to the inside panel and the inside panel is turned off and the outside panel is on, the wires B & W wires are not hot.
What is going on?
