I am trying to repair this low viscosity fluid pump, I have the original start and run capacitors but do not know how they are wired. When I found the pump Z2 and U1 were connected between which confuses me on how to proceed with the rest of the connections. Also I am very unaware of the purpose of X3 male. I attach a photo of the state of the connections as when I found it, hope someone can help this ignorant fool. Documentation regarding circuitry is nowhere to be found, it is however a single phase 220 volt pump. Model number is: 2BV3151-0GW02-1E. More details in the respective datasheet:
http://www.compressor.fi/media/EsitePDF/2BV3_vacuum.pdf
Color coding is as follows:
- Z2 black
- U1 white
- Z1 green
- U2 pink
- N and L1 both red (unaware if correctly placed)
