I need to extend some 4" PVC drainage pipe. The problem I'm having is that the existing pipe is "Type C" ("tele-duct"). It has a slightly different outer diameter (4.350") than a typical PVC pipe (e.g. Schedule 40, 4.50").
I've only been able to find one possible "Type C to Schedule 40" adapter product, and it's from a wholesaler with a high minimum purchase. Is there any way to wrap the existing pipe with some kind of sheathing to increase the outer diameter before cementing it to a "normal" Schedule 40 fitting?
