I have two adjacent light switches in a bedroom. One switch is intended to operate 4 recessed lights, the other is intended to operate a ceiling fan/light (via a wired remote). When I bought the house, both switches worked and operated the fixtures independently. Some time later the remote switch stopped working, so it was removed (I did not note how it was wired, thinking it would be easy to wire). Fast forward 2 years later to today, I'm finding only only one HOT wire in the box, and one circuit wire that leads to BOTH the recessed lights and the ceiling fan (confirmed via operation or continuity test). There are ground and neutral wires that are wire-nutted and another black wire that is neither hot nor connected to the fixtures.
How is this possible?
I can't seem to wire both switches to operate the circuits independently, but I'm fairly certain is was wired as such (have had the ceiling fan switch removed for some time).
Attached a clearer picture. Wire summary follows:
Black wire, lower left, yellow nut (HOT); Black wire, lower right, yellow nut (leads to ceiling fan AND recessed lights); Black and white wires, upper right, white nuts (no apparent function)
