Yesterday I discovered that part of the carpet in the basement is soggy and there's a sewage-like stench. I've contacted both the water damage restoration company and the insurance company to evaluate the situation. The restoration company said it's likely a backed up drain underneath the carpet and that they will come Monday to remove, dry, and replace the carpet; They did suggest I contact a plumber first to check on the clog.
I'm not asking about what needs to be done to deal with the wet carpet/smell, since that will be handled by the restoration company. I'm asking if there's something I can do before Monday as a temporary measure before the smell and bacteria/mold gets worse?
Edit: I'm considering of throwing some drying agent like kitty litter or something and then run vacuum and carpet cleaner over the area as a stop-gap measure. Would this be advisable?
For the curious, it doesn't appear to be a foundation leak or sump pump overflow because all areas around the wall and sump pump are dry. The wet spots appear towards the middle of the basement away from the walls.
